Hello and welcome to Android Forums. I would try two things. First I would open your player in your phone and press play. You should hear the song via your BT headsets. I would also check the instructions with your BT headset. It likely has a button to push to initiate the playing of a song as well. If you have tried both of these things and you still do not hear your music I would delete the BT connection and try setting it up again. I've had to do this before to get a 100% pairing between phone and headset. You might also want to check in with the users of the Galaxy S and see if there is some special trick I am unaware of. Those users will be found here: Samsung Galaxy S - Android Forums Best of luck to you and thanks for joining AF.
