Apps How to locate an image inside ExpandableTextView?
Ayush95
Hi, I created expandable text view's in a Fragment. It is working fine as of now. But may i know how can i place an image inside it (as if, that image should not be displayed before expanding the view).
Can anyone help me in this.?
Attached screen shot for reference. I want the image icon, inside the expand contents.
Code:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:expandableTextView="http://schemas.android.com/apk/res-auto"
    android:layout_height="wrap_content"
    android:orientation="vertical">
    <TextView
        android:id="@+id/title"
        android:layout_height="36dp"
        android:background="@color/title_bg_color"
        android:gravity="bottom"
        android:padding="5dp"
        android:singleLine="true"
        android:textColor="#333333"
        android:textSize="18sp" />
    <com.ms.square.android.expandabletextview.ExpandableTextView
        android:id="@+id/expand_text_view"
        expandableTextView:maxCollapsedLines="2">
        <TextView
            android:id="@id/expandable_text"
            android:background="@color/text_bg_color"
            android:fontFamily="sans-serif-light"
            android:textColor="#494848"
            android:textSize="16sp" />
        <ImageButton
            android:id="@id/expand_collapse"
            android:layout_gravity="right|bottom"
            android:padding="5dp" />
    </com.ms.square.android.expandabletextview.ExpandableTextView>
</LinearLayout>
