Droid Chris
Since there seems to be nothing on the web that directs us novices to the keytool.exe for creating keys, here is what I have found out (for windows)
1. Go to start
2. Select windows command prompt
3. Change directory to C:\Program Files\Java\
by typing in so after user\user name: cd C:\Program Files\Java
4. type in dir to see what type of java you have then type in cd (your java type)
for me it was:
C:\Program Files\Java cd jre6
5. Then change directory to bin
C:\Program Files\Java\JRE6\ cd bin
6. From there you can run the keytool command that every tutorial tells you to
1. Go to start
for me it was:
