How to lock task manager?
RFido
Okay I am using Galaxy S2 and I have recently upgraded the firmware from ICS to Jellybean.
Everything works fine and brilliantly.
The problem is with the task manager.
Say that I don't want anyone to see my images, you install an app locker and you lock the images app and my files right and this should work fine.
Unless someone opens the the task manager force closes the app lock then he will be able to view your images and once they are done they can start the app lock again so you would not suspect a thing.
This was not an issue with ICS as I was able to lock the task manager on ICS but not on Jellyvean.
What is the use of an app lock manager if it can be killed in task manager?
Anybody faced this before?
It's kinda a big deal.
