How to long press for capitals
I love my Blackberry for this - I just hold down the letter and it gives me a capital letter. Is there any way at all I can get my Nexus 7 to do this?
TIA.
Moved to Nexus 7 section. :) Welcome to AF, by the way. :ciao:
Never used a tablet, but you should see an arrow key pointing up and pressing that will give you upper case letters. Hope this helps. :)
arrow key on the left. press and release, then press the letter - capital. if you want caps lock, double tap the arrow key. then tap again to end caps lock.
Thanks to both of you, but I have been using the up arrow key on my computers since 1988 and on smartphones for years. :) My issue is not either of the above. I want to be able to simply hold down the key for any letter and get a capital, much like the Blackberry. Simply put, I want to use only one key to accomplish this. Is there any software that can do this? I have installed Perfect Keyboard and Go Keyboard, neither of which addresses my need.
