How to make scenes interactive?
thahim
I want scenes to do differwnt things like
When I tap on it . It may disappear.
How can I do this?
When you first start creating a scene, the first window should be your background. Resize it to your desired dimensions. Then in the lower bar there should be a magnifying glass.
Press that and now you can add elements.
Long press the background and it should bring up a menu. Select your desired element.
An example would be to select a button element. Then press lower left hand icon and you can resize and/or move that button within the background.
You can then tap the button and it should bring up element edit options : UI/Tap/Long Tap
Select the Tap or Long Tap to assign actions to the button element . If you want you can add a series of actions then also add Hide Scene and/or Destroy Scene so the scene closes after selection.
I havent tried all the different elements so I cant speak on how to do it with them all but should be similar.
