Help How to make wifi network hidden?
bigpower1
I am currently using Binatone 150M Wireless N Router, Model No. WR1500N and i wanna hide my wifi network from others. I am using this wifi router first time thats why i don't know how to make wifi network hidden from others.
First of all person have to fill user name and then will get option for password because i don't wanna that any one will see my wifi rang and tell me to give wifi password.
Here is option of my wifi router :- http://i.imgur.com/3UEz1R2.png
Hope you guys will help me.
You can stop the ssid being transmitted but thats it. If it is hidden no device would be able to see it. Make sure you use a strong password
Hi
Here is a link to the manual: http://www.manualslib.com/manual/815795/Binatone-Wr1500n.html?page=34#manual
On the wireless settings page, untick "Enable SSID Broadcast" Restart the router - that should do it.
Roger
Not familiar with that make of router, but you may even be able to do it in the Quick Setup, as it's a pretty basic setting. What you are looking for is an option to turn off SSID broadcasting.
Thanks to all of you. Its hidden now
