How to monitor WiFi disconnects using Tasker?
ldm1417
Member
Hi All,
Hi is it possible to monitor WiFi disconnects using Tasker?
I tried to do this using the 'HTTP Get' command, but the %HTTPR variable receives the '200' value even there is no a real connection to the Internet. Only then WiFi is OFF, %HTTPR=-1, in all other cases %HTTPR=200.
What another method to keep a eyeon the WiFi disconnects?
Thank you!
Monitor connects
Code:
Profile: AAC
State: Wifi Connected [ SSID:* MAC:* IP:* Active:Yes ]
Enter: Anon
A1: Flash [ Text:Connected Long:Off ]
Monitor disconnects
Code:
Profile: AAD
State: Not Wifi Connected [ SSID:* MAC:* IP:* Active:Yes ]
Enter: Anon
A1: Flash [ Text:Disconnected Long:Off ]
Run with both of them enabled.
… Thom
