Help How to move most possible data to sd card.
JonathanWhitey
Does anyone have any suggestions to move the most amount of possible data, files, pictures and everything to sd card? I know that I cant move all of it due to limitations in these later versions of android. Ive gone through in application manager and moved all that I can, but i want to know if I can move more. Any help is kuch appreciated.
Try going to my files.
You can move to or copy to more files that way.
I did this. Still not much I can move. I try to move obb files (from games), and the games no longer function after that. I also try data files and those break the apps as well.
Edit: I suppose that if rooting is my omly option, I might elect to do it. Ive done it on all of my previous smartphones but never anything as expensive as a gs5.
