You probably have not heard about the phone if you are not from India . Name of my phone is " Intex Aqua Wonder " .
By using " ES file explorer " I can access the apk of the note pad app and a file named notepad.odex . But I am unable to find the location where the note pad app is installed .
Only options available in the app are " create " and " delete " . I think the app is a stock android app . My mobile has android 4.1.1 . Is there a way to make a backup of the app and then install it in an another mobile with its data( texts ) .
