kumaranil13k
I am trying to root my mobile device main reason was to move apps or use apps like app2sd link2sd apps for moving apps but I forums experts suggested many alternatives. A solution to format as as internal and moving app to SD card and editing app manifest without rooting it's partly working.
As Google and forums answers many recommended not good to move all apps to sd card.it's good to move static files as random using file may slow down proces.
So I thought except apps moving what's benefits and Drawbacks of rooting and is worth it so founded following benefits and drawbacks
Benefits and alternatives
12. Does mobile become secure and cannot. We overcome rooting drawbacks if we root make tweaks and then unrooot it.
13.. Does after rooting through kingoroot iroot or twrp or magisk after unooting leaves any after strains or left out files in mobiles which one of rooting procedure is safe and good for rooting and unrooting
Kindly do forgive any mistake kindly do correct me if I am wrong somewhere bcoz correcting my knowledge mistakes will improve my and other readers doubts and improves our knowledge.
Thanks for sparing time for reading long question and thanks a lot for replying sharing your precious time advice opinions
Any more advices opinions suggestions are most welcomed
- Periodical backup of stock ROM (Alternative without rooting adb pull)
- Uninstalling bloatwares system apps (Alternative disable apps)
- Moving apps (Alternate format As internal editing mainfest moving apps)
- Installing flashing custom Roms (Risky but can be used virtually without flashing)
- Cleaning David cache and junks in system (risky not mistakenly delete s any system file)
- Battery optimization
- Sound optimization
- Tweaking
- Hacking patching apps games
- overclocking
- Blocking Advt ads free
- Hacking wifi
- Using VPN on mobile
- Void warraNty( no warranty left)
- Bricking phone (backup stock ROM)
- Virus malware spyware ransomware
- hacking of camera or calls recording
- Update of Android and apps
- Banking or payment gateways don't work
- Tweaks risks
- Wrong file delete or wrong settings can harm
- Can we root and tweak or modify any settings and later unrooot then  will these modification alterations changes modifications  work after unrooting to or not?
- Can we do factory reset without unrooting if something some settings goes wrong will factory reset recover us unrooted versions of android back
- Does while rooting if mobile device  software bricks, then Will hard reset factory reset work, if not, then will bootloader mode  work. As I want to recover Stock ROM system files  by loading adb or fastboot twrprecovery.img  after software bricking. can stock ROM system boot be recovered by recovering stock from or flashing  from  from backup system boot userdata images through tarp recovery or adb pull or DD if commands. If after software bricking hard rest I menu or  bootloader or twrp recovery menu  don't work then how can we recover back or flash back the stock from.
- Will link2sd apps moved apps work if we root mobile device and move or link apps external micro SD card and then Unroot or link2sd app constantly permanently need rooted phone to link update link every time booting the phone.
- How can we protect the rooted phone from malware spyware  ransomware or from hacking any way firewalls or way to protect them? Is there any way out any firewall antivirus VPN way out in rooted phone or if we unroot phone after modifying tweaking then will unooted. Phone more secure safe or will be secure with antivirus atmosphere antimalware or malware
- As OEMs Android updates and apps update not work in rooted phone is there any way out to update those or to auto download be auto notify for new update for. Apps.
- As banking payment gateway apps blocks is there any way out to use the. After locking or magisk have option of hiding root info
- In all I want expert advice opinions and to ask how to overcome secure from Disadvantages of rooting mobiles
- At last I want expert advice that is rooting worth it in sacrificing security and opening mobile for hackers malware's spyware. if I don't root than can the advantages of rooting be achieved by alternate apps or advice shall fast boot commands it alternative ways to modify tweaking mobile layout sound wifi vpn without rooting.
