Help How to prevent volume rocker turning from vibrate to sound?
spman
I always set my Samsung S4 to vibrate mode.
When I accidentally press the volume rocker + (Up volume) button, phone will change from vibrate mode to sound mode.
How to prevent that?
This sounds like it might be worth a shot:
This app helps prevent against accidental volume changes by confirming the change you made, by either tray notification or a pop up. If you don't approve the change, the volume will be reset within a set amount of seconds. Great for people who accidentally changes their volume, have small kids, don't want their phone to go off accidentally in meetings, or even have apps which modify the sound settings a lot. It works with most profiling apps: Locale & Tasker ("Locale Audio Update Notifier" plugin necessary), Timeriffic, Setting Profiles, Ring Toggle, AAM, Bedside, etc.
By setting the timeout to "instant", the locked volumes will revert instantly without prompting.
https://play.google.com/store/apps/details?id=com.hourdb.volumelocker&hl=en
