What exactly did "standby" mode do in the Droid X? I assume it was like a computer sleep function.
Anyway, the S3 does not have this feature. The best you can do is put the phone in airplane mode. That will turn off the radios, and the battery will last a long time if your not touching it. It's technically still on however. I assume the Droid X powered down to a very low active setting. Again, like a computer does.
Standby is enabled by turning the screen off, same as every other smartphone.
Sounds like you've got the idea.The OP is not just talking about "locking" the screen. The phone is still working from that point.
It sounds like the Droid X had a feature for sleep mode. Which would save battery, but at the same time allow for users to have a faster boot up when they resumed the phone. It would useful for a plane trip. As well all know, after a while, the phone takes longer and longer to boot up from a complete power off.
I also assume that sleep mode would allow most programs to remain active when you resumed. Powering off will completely kill and turn off all applications and processes. These are all assumptions, as I did not own the X.
Airplane and power saving mode would work well as a combination.
My battery only dropped 5% over eight hours with airplane mode on and I was taking pictures. The radio uses almost as much power as the display, if not more so! The battery reporting indicates it uses less, but my phone would usually drop about 20% over that time period.
So, how do you enable, "Power Saving Mode"?
thx
Well that would be kinda pointless on the S3 since it boots up literally in seconds.
If the OP isn't worried about getting calls, texts, or emails while in this sleep mode, why not just shut off the phone? It would take a lot less effort to just power it off/on rather than enable/disable airplane & power saving mode each time. It takes around 5-10 seconds to shut down and around 30-45 seconds to power up. Granted it's not instant, but it's a helluva lot faster than powering down/up a phone on gingerbread (mine was around 15-20 seconds to shut down and 1-1.5 minutes to power up). Obviuosly you wouldn't lose ANY battery with it powered off, and you'd be looking at tops of less than a minute spent cycling power. Just a thought.
No, it's easier to pull down the notification bar and tap the airplane mode button. Compared to a complete shut off.
If all he's doing is that I'd agree. But to do both airplane mode and battery saving mode, as long as you don't need it instantly it would be easier, plus it would start you out fresh in terms of RAM as well.
