First turn off your phone and then press power and up bottom and home bottom at the same time then let go power bottom when you see the phone on but keep holding the up and home key untill you see the you boot in recovery
Partly correct. First off your phone, then pres and hold "pwr + vol up + home button " same time it should vibrate let go once it does and after the logo it will show your recovery.
For download mode same thing but instead of vol up you will replace it with vol down so "pwr + vol down + home button"
