A
Android Question
Guest
I have an HTC Legend - which I recently had to factory reset (ran out of phone memory and deleting apps/clearing caches wouldn't release the memory). When I came to reinstall apps, I found they weren't listed in Google Store - and then realised why; most of my apps are for Android 2.3 upwards (which is what I must have had previously) but I now have 2.2. If I check on available software updates, it says there aren't any. I've looked up the process to change from 2.2 to 2.3 and it looks frighteningly technical (e.g. tells me the phone has to be "rooted" - what does that mean??). Is there any easy way out of this dilemma?
