wetbiker7
Extreme Android User
How to remove deleted posts.
If you make a post that you later want to delete, just remove your text, replace with"deleted" and hit the REPORT tab. Let the staff know that you want the post removed and give the reason. This also works for posts that you come across were the user has deleted their post. Thx
