How to remove personal data from Android that I am returning
Hi Al, welcome to the forums.
If you format/remove your SD Card and perform a factory reset, that should be more than sufficient of removing any personal data from the phone.
Welcome aboard.
Thanks for joining the community. ;)
Just to add a little...
A full reset of the device - with the 'wipe sd card' box checked (that's if you are planning on not keeping the sd card)- and you are good to go. :)
