sandorhadasdig
There are a couple of boxes under a Jenkins build farm to which I have only a shell ssh access. There are several android versions installed under /Developer/android-sdk-macosx .
How do I delete specific versions using the /Developer/android-sdk-macosx/tools/android command line tool (after using for example: android list sdk -a).
Or, what is the proper way to remove it all and reinstall and also make gradle happy with that?
