How to remove Spiderman 3D??
HoltNFrew
I want to remove Spiderman, I uninstalled it, but the Icon is still in the menu... Is it possible to completely remove it?
Thanks
You can root your phone to get rid of it.What phone are you using? Evo 3D? Let me know if you need any direction on how to do that and ill point you in the right way.
Unfortunately for whatever reason cell phone manufacturers have decided to include copious amounts of bloatware on phones with no option to remove them. My Dinc2 has Need For Speed Shift and some golf game that is just permanently on there. What sucks is you need to root your phone to get that stuff off but, rooting your phone voids the warranty. :(
So you are kind of damned if you do and damned if you don't. You can root and remove it and void warranty or keep your warranty and be stuck with garbage on the phone.
There is a great step by step for rooting here:
[GUIDE] Root Your EVO 3D: a step-by-step for the average user [v2.1][NIGHTLY UPDATES] - xda-developers
after youre rooted you can download Root Explorer, Astro File Manger, or a similar program from the market and it will let you remove the apps you do not want. The process looks a lot more daunting than it actually is, even I managed my way through it and my only previous rooting experience was with my old Epic and that was a simple one click method. This is actually pretty close once you read all the info and start it up. Feel free to PM me if you have any questions or concerns if you decide to go the root route.
Ingenu you're in Atlanta? I am too. Been hot as hell. Keep cool man.
