Help How to reset Android on Galaxy mini
matrix69
Hello guys , i have a big problem with my phone , when i started , i recieve a error and can not do anything , I still this error appears , i can`t entering in the settings menu . My question is , can reset the phone by button combination ? Sorry for my bad English.
I resolved this problem , with :
1. Power off phone
2. Press and hold Menu Button ( middle ) + power on for at least 10 seconds
3. Android System Recovery Mode Appear
4. There are 4 options
  • reboot system now​
  • apply sdcard:update.zip​
  • wipe data/factory reset​
  • wipe cache partition ​
5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
6. After the process done, phone will reboot.
OMG Thank You! matrix69 i fixed my home problem: "Sorry The application Samsung Home (process com.sec.android.app.twlauncher) has stopped unexpectedly. Please try again."
Hello guys , my phone Samsung Galaxy Mini , it does not start blank and it doesn't even turn on or respond to being plugged in
i can`t reset the phone by button combination. i can`t do anything plz i need your help
