Help how to reset the boot animation
ayrshiredude
I have installed Dark's rom and its changed the boot animation to a dary one whihc I really don't like. Is there any way to change this back to the proper SGS one?
Thanks
Except there's no stock bootanimation.zip. The stock boot animation was in qmg format, which doesn't work on a custom kernel.
OP, just go find a bootanimation you like and replace it.
On Darky's forum there's a bunch of bootanimations available.
I installed mine through CWM (install zip from sdcard).
