how to reset
  • Start date Start date
press volume + and power key both.. then it will show you triangle.. release all button.. then press power key.. it will show u menu.. then use volume down key to move.. for OK press (first power key then volume + key at same time).. that's it, u can easily format your phone..
Remember, you loose all data and apps with a factory reset.
