- While this may not give you a lot of memory back, I'm sure it is enough for most of you people, it involves putting your apps into the system rom, therefore away from the internal storage.
- NOTE: Not all apps can be installed into the rom. The apps that I know that work are most of the Google applications and most of the social media apps. Dolphin browser also works fine so I assume other browsers will work as well. I have not tried games or any other apps so you are going to have to try them yourself.
- If you move an app to the system rom and it doesn't function properly, simply move it back but of course it should be wise to BACKUP before attempting this as anything can happen.
Step 1: Go to Google Play and look for system app installer or app mover, there are many apps out there that move apps to the system rom, this is the one I use https://play.google.com/store/apps/details?id=de.j4velin.systemappmover
Step 2: Grant them superuser access and simply start moving them over to the rom. I recommend doing one at a time to see which ones work and which ones don't. Again a backup isn't required but it's recommended. Cheers!!!!
