Hey Androiders,
Here's what SoD looks like for me:
- phone will hang, or shut it self off and then I can't wake it with the power button, the trackball nor the volume rocker
- pull the battery, put it back in, reboot one of three things happens:
1. hang on the 4 colour x
2. hang on Cyanogen Mod loader screen
3. boot fine, but won't let me unlock the phone (gesture unlock before you input your secret pattern)
Here's what I've tried:
- as per lunatic59's suggestion in another thread I cleared the memory which made me think that I had fixed the issue until #3 happened again
- talked with a repair guy with a little hole in the wall shop here in Toronto who says it's a motherboard issue and he has to change it for CAD$150
- talked with HTC who said send it to us for diagnosis, we'll fix it and if it's the motherboard it'll cost US$197+shipping
What I still need:
Your opinion(s) as to what can I still do to fix the issue myself, or a recommendation which of the above solutions you'd go for. I'm kinda leery of the repair shop dude because he talks a mile a minute and I can't understand him which is making me think he knows his stuff.. but still.
Also, what replacement device would you recommend? I was warned off Samsungs because of the possibility that they will run into the same issue with the motherboard (fusing of pins due to extreme heat) in the future.
Thanks in advance for reading and taking the time to respond!
JMak
What I still need:
JMak
