silverfang77
Rooted Droid 2 with Froyo 2.2 and 2.3.20 system update
I rooted my Droid 2 using Doroot, installed Titanium Backup and proceeded to stupidly uninstall the Skype bloatware that Verizon and Motorola so thoughtfully put on all our Droids.
Only later on did I learn that in order to receive OTA system and OS updates, one must have all bloatware present and accounted for in the /system/apps folder.
Can I use the skype_mobile.live.apk file that I downloaded in a Droid X backup file, or does the Droid 2 use a different version? If I can't use the Droid X Skype file, does anyone know where I can get the Droid 2 Skype file?
I'd like to be able to restore it without wiping the phone and reinstalling everything if possible.
And yes, I have learned my lesson about impulsively uninstalling apps that come with phones, even annoying ones.
Thank you for any help.
