JALStudios
Member
If you would like to go back to stock because you don't like the root or you Semi-Bricked your phone?? Well you are in luck! Because all you have to do is download the files below and use Recovery mode to install them!
If you want to flash back to Android 2.1:
Stock Kernel---http://www.mediafire.com/?dfbfr3gxm720zit
Stock Recovery---http://www.mediafire.com/?8nh0tqi6exg1y75
Stock ROM---http://www.mediafire.com/download.php?5xreqq7iqfa6ofd
If you want to flash back to FROYO 2.2:
Stock FROYO Kernel---http://www.mediafire.com/?cmpsuh38m3kgu12
Stock FROYO Rom---http://www.4shared.com/zip/rO5KLnzf/VirginMobile-Froyo-StockROM.html
Stock Recovery---http://www.mediafire.com/?ysbnq07a4j2z999
MAKE SURE YOU ARE DOING THIS ON A VM INTERCEPT!! NOT A SPRINT INTERCEPT! IF YOU FLIP-FLOP IT YOU WILL COMPLETELY BRICK YOUR PHONE UP!
