Help How to root 2.3.7 ViewSonic viewphone 3
mlrkumar
Recently I have purchased viewphone 3 with Android 2.3.7.When I try to install backup pro .It says your device is not rooted.So I tried with gingerbreak,Unlock Root,z4root, UniversalAndroot-1.6.2-beta5,SuperOneClickv2.3.3,Still I was unsucessfull.So I Download superuser.zip and universal_gb_root.zip to Install from sdcard,rebooted my phone.Press power button along volume +_ to recovery mode. I got boot menu
When I move my Volume Up and down , to Select ,Cursor does't move but works fine with android app,It goes FTM MODE.
So I connected usb to pc from command prompt I used "adb reboot recovery",I selected update from sd,Tried to Install universal_gb_root.zip I get Error signature verification failed. but I am able to move the cursor in recovery mode.
I Tried All Methods after googling in the Internet .but device is working fine 100%.Please Help to unlock/root/bootloader also.
For rooting and uninstalling preinstalled app:
1) Download SUT LR
https://rapidshare.com/files/559763473/SUTLR_v1.8.2.7z
2) Download New Android Firmware for viewsonic with rooted.
www.rapidshare.com/files/253791827/firmware_root_MarcoCH.7z
( after downloading Extract it)
3) Install SUT LR in XP and Connect Mobile to PC.
4) Open SUT LR and Click Next-> Select the firmware.nb0 (options Leave "none" Next--> It will take some time Click -> Finish.
5) It Will automatically reboot the device.
6) Install Root Explorer (download it from 4shared.com)
7) Open and goto system/app
8) click options select the app and delete.( but be careful before deleting ,if some appications are dependence ,It may crash , So Take a backup with root explorer and delete.
9) It Worked For Me ......
If you do so...
you will loss original firmware...(you will not get it back any way..there is no way).
you will not get separate ringtone for sim1 and sim2...
Ok the other way is flash with (xml_v350.zip) some file and
root with superoneclick...
thats it.
Now I have the original firmware and Root access...
Regards,
Sri.
1) Download SUT LR
(before that you have flash with some XML file).
thanks for the feedback, the part above I dont understand???
can you pls clarify???
Update
OK found a few new things
1- need to download 2 things SUT_LR_1.8 and XML_V350.zip (bad start all the links I found for these two where dead...
2- run SUT_LR
3- transfer couple files (which ones???) to cel using SUT LR???
4- run SuperOneClickv2.3.3 and it should work???
help anyone??? any ideal where I can download these
Update 2 : looks like all I am missing is where to download xml_v350.zip?
Update
2- run SUT_LR
Hi,
First you need to check any updates for your software...
Once it is updated you will have a file with .nb0 extension on your micro SD card.
It is used as a backup or original software.
Then you can go for ROOT your Phone.
You can find the forum how to root and download links are in
Startseite - Mobi-Forum.de
you have to use Google translator to translate it from German to English.
Regards,
SRI.
I been following what SUN-Jack did in the german forum Viewsonic V350T (Viewphone 3) firmware 5057_4_39C with and without rootaccess (no SUT necessary) - Viewsonic - Mobi-Forum.de and it WORKED 100% for me...
this procedure is simple and worked 100% first time for me and finaly got my Viewsonic ViewPhone 3 V350T rooted 100%
BTW Yes Google Translate can help on this mainly German forum, but they been very opened to responding to english post and even better they been posting often in both German and english when they know english users are tracking a thread... great bunch of guys!
happy Camper!
Richard VE2DX
Hi,
I have tried everything from above and i seem to be getting error after error. Is it possible to root android 2.3.7. I am hoping it is something small but i am not able to get passed this and it is really driving me mad, pleasehelp!
I really need to sort out my internal memory, it wont allow me move to sd and any app i download it requires superuser or root so you can see i needto get this sorted before i attempt to sor out my internal storage issue.
Thanks,
Aoife.
phone details are as follows:
Viewsonic View phone 3
Android version 2.3.7
Kernal version Apps_2.6.35.11-perf
Build number 5057__39C
Hi Team,
please check my blog for the same, I successfully rooted my View Sonic, View Phone 3.
gadgetsfreeak.blogspot.com
Rgds
Jignesh Mehta
Hello people,
I know this is an old thread, but I'm trying to root my Viewphone too (just now).
Sadly, most links are dead & the only thing I found was the firmware file by "jignesh81".
On that one, after rebooting in recovery mode etc, I got a message that the file was eighter wrong or corrupted.
Can someone provide me a good firmware.nb0 file? This phone is driving me crazy :/
Hope you get to read this.
Thx in advance!
Seveneke
Ps: Android version 2.3.7 - build 5057_4_39C
