ravinOrion
Here is the step by step method to root your Atrix 2 running ICS 4.0.4 :
( It worked for me 100% on my Atrix 2 ICS 4.0.4 Indian version )
Credits : The XDA Developers ..
I assume that you have all the drivers installed and have the original Atrix 2 data cable.
step 1 - Download the file (highlighted in red) that you will need to root:
( The unzipped folder contains ROOT.bat and not UNROOT.bat ; so please don't ask me how to unroot it ; for the time being )
ICS_Root_Atrix_2.zip
Step 2 - unzip the file on your desktop
Step 3 - open settings on your phone and tap on developer options
Step 4 - Check "USB Debugging"
Step 5 - go back to settings and tap on security
Step 6 - check "Unknown Sources"
Step 7 - connect phone to pc using data cable that came with the phone
Step 8 - select computer connection as Camera (PTP)
Step 9 - First run ADB.exe from the folder you have extracted ( important )
Step 10 - When the program closes run ROOT.bat
Progress :
As soon as you run ROOT.bat .. your phone will reboot quickly ...
Now just sit back until you are asked by the ROOT.bat window to press any key to continue.. the phone will reboot several times ..
Don't touch your phone during this entire process.. it may take 3-5 minutes in the overall rooting..
Once you close the ROOT.bat window.. wait till the phone reboots and back to your home screen..
yay...!! Your Atrix 2 is ROOTED ...
Progress :
