Root How To Root Micromax A110 [Micromax Canvas A110] : Exclusive guide
sagarwep
Hi Friends,
I Have Bought Micromax A110 Canvas 2 Yesterday.
---Good Phone support HD video and HD Games.
===Spacification===
--- 1Ghz Dual Core Processor
--- Android 4.0.4 ICS with update
--- 5" Screen with good tuch
--- Dual Sim with interchange 3g Mode
--- Bluetooth 3.0
--- 2000 mAh Bettery
--- 512 MB Apps Memory and 2 GB Internal Memory
===Rooting===
Micromax Canvas 2 i.e. Micromax A110 root by Bin4ry's rooting tool. Thanks to Bin4ry's for this rooting tool. This device was recently rooted and thus enjoys superuser access. The development for this 5 inch dual core processor powered Android Phablet will, for sure, be accelerated with this. The rooting procedure is really easy, and you will follow the given Procedure ---
1--- Enable USB debugging on your device. To do that, go to Settings > Development > USB debugging.
2--- Connect your device to any PC/laptop. The drivers will be installed automatically.
3--- Unzip the root tool you downloaded by given link.
4--- Run the runme.bat file.
Download Tools --- Bin4ry for Root A110 By sagarwep.7z
5--- A command prompt with weird green letters will pop-up on your screen.
Follow the onscreen instructions carefully. To start off, you willl need to type in a "1" and press enter.
[Note: If you ever want to Unroot your Micromax A110, follow the above steps till you reach this one and then, instead of typing "1", type "x" and hit enter. Follow the instructions that appear on the command prompt after that.]
6--- Your device will reboot during the process after which Bin4ry will copy some files to your device.
7--- When the green letters in the command prompt says Have Fun!, then... Have fun.
8--- That means, your device is rooted now and you can enjoy Superuser permissions!
----By Sagarwep
Thanks sagerwap for taking initiative...I also bought this fone simply fabulous....value for money...
Thanks once again..
one request if possible please check solution to download HD game data on sdcard2(external sdcard), by default it try to download on sdcard(internal sdcard) but fails because of space unavailability...
This is what I found please check out....
How to install app in external micro sdcard in micromax a110 - Complete Guide
---This guide for default internal sd card but this is risky because CWM recovery not avilable so wait some time. I m provide custom recovery after some time.
---for game download via google serch and install menually apk and move to external sd card and copy data to external sd card.
How is the :-
1. Performance, did you experienced any lagging?
2. Internal memory size?
3. HD Games performance?
4. Dual standby working, means second sim live when attending call on first sim?
5. Screen resolution is good or not?
How is the :-
1---good performance and smooth
2---hd games support
3---working dual standby
4---almond screen with multi touch...
I am facing gps locking problems and it is not downloading the epo files it is telling that epo files update failed plz plz plz help me
I goofed up up somethingafter rooting . my gmail, google play nything related google not working.
factory re set not working :(
help pro's
please
I am in really a mess snow. I have rooted the device and tried to change the swap the SD card by editing the file vold.fstab using ES file explorer and by Replacing the sdcard with sdcard2 and sdcard2 with sdcard and saved the text and rebooted the device and now the Phone is not detecting both the memory cards showing as External card error.
Please Please Please help me . Its very urgent guys.
Thanks
When I opened the Es File Explorer i get the below error message.
SD CARD EMPTY, UNMOUNTED OR NOT PRESENT
Please Guys save me . I badly need help in this. Please Please Guys.
Thanks
If u use Vold.fstab modified file follow the following instruction -
---First download the modified Vold.fstab link here
---After that use root exploler and go to directory and replace file
---And set permission -rw--rr--
---Reboot....
Nice guide for rooting...
could anyone please tell me how to root this
Micromax a110 from a Linux machine. I'm using Linux Ubuntu
12.04lts?
And I have a problem. while charging the device
It misbehaves with my touches. When I touches
The phone it responses with irrelavant operations.
It responses with some other operations where I didn't actually
Touch. This problem persist only when I'm charging
The phone. Could anyone please help me? Thanks in advance.
Purchased on Nov 7th...
Awesome phone!!! But 2gb internal storage is not enough for
Gaming. I would prefer directory bind to play games from external SD.
Will it be fast enough to play games?
which charger u r using??
original one??
the touch screen sucks in android mobile when u use 3rd party charger with higher or lower voltage
I too having same EPO data download problem .... unaable to understand the issue...I found GPS navigator is slow...!!! :-( ... what is the other's thought on this..
