Root how to root micromax a45
it's cannot working for me.... how to use super one click please give tutorial.... plz
firstly dissable ur antivirus...
1)download drivers available at micromax's site
2)Connect your device on your PC and be sure that USB Debugging is enabled.
Your PC will ask on how will you install the driver, choose
how to install a45 driver....
download drivers>>>>then switch off ur device and connect to pc>>>it will try to install drivers but fail>>>then go to control panel>device manager>in that there will be an unknown device>>>right click and click update software>>
then choose from specific folder where u extracted the drivers>>
then simply install it>>>u r done....:D:D:D:D;):D:D:D:D
Thankxxxxxxx.... Rishu i have root my phone,,,,,,
Also in driver files only these three files have been found(read me ,tetherxp,ReleaseNote_RNDIS_v1.1104.00)..only these three files enough?
how to install drivers in windows 7
download it from micromax's site!
it should contain
ES980 USB DRIVERS
TETHERING
DRIVER-USB VCOM DRIVER (BINARY)(1)
its not working for my Micromax A45 its not responding and getting blocked on wait for device what to do please help its a humble request PLEASE!
