Superbrowndude
Model Number
X10a
Firmware Version
2.1 Update1
Baseband Version
2.1.55
Kernal version
2.6.29
SEMCUser@SEMCHost#1
Build Number
2.1.1.A.0.6
I was using Free X10 Beta 4 and was missing my HD Camcorder,so I used the option repair through SEUS and got the latest firmware which is .55.
Then I used the XDA flash Tool
Multiupload.com - upload your files to multiple file hosting sites!
Connect the phone(make sure USB Debugging is Enabled,DO NOT mount Sd Card),then click root.
Congratulation's you should now have root access
You can also install XRecovery using the flash tool,click advanced then select install XRecovery.
Download Busybox from the market,not the one in the flash tool.
If this helped ya,Click Thanks
X10a
Firmware Version
2.1 Update1
Baseband Version
2.1.55
Kernal version
2.6.29
SEMCUser@SEMCHost#1
Build Number
2.1.1.A.0.6
