Staff
Android Expert
There are multiple ways to record the Screen on your Galaxy S20 Ultra and we'll discuss and explain them all here, starting with the most popular method.
How to record the Galaxy S20 Ultra Screen:
Screen Recording Tools
Once the recording begins you'll see a toolbar at the top right which provides these additional options:
To access even more options for the Galaxy S20 Ultra built-in screen recorder you can open "Quick Settings" again and press and hold on the "Screen recorder" quick toggle. You'll have the following advanced options:
Best Screen Recording Apps for Android
You can also record your screen by using Android Apps from the Google Play Store that may provide additional options and functionality not found in the built-in Screen recorder for the Galaxy S20 Ultra. Our favorite happens to be AZ Screen Recorder.
- Open Quick Settings by swiping down from the top of your screen twice (or you can swipe down with two fingers)
- Swipe to left and tap "Screen recorder"
- Select if you'd like to record with "No Sound", "Media sounds", or "Media sounds and mic"
- Tap "Start Recording"
- Arrow icon: shows current duration of your recording
- Pencil icon: allows you to draw on top of the screen
- You can tap the color bubble to change your drawing color
- The left arrow will "Undo" and the right arrow will "Redo" your changes
- User Avatar: adds a bubble that records using the front facing camera
- This is ideal for recording yourself talking while screen recording
- The small bubble on your screen can be moved around my long-pressing and dragging
- Square Button: Stop your recording
- Sound
- No sound
- Media sounds
- Media sounds and mic
- Video quality
- 1080p (default)
- 720p
- 480p
- Selfie video size:
- Small
- Kinda small
- Medium
- Kinda large
- Large
