Root How to send MMS on Orange with 5.3
Jaffa
Android Expert
Finally cracked it
This is what you need to do
The settings under Production need to be
MMSC: http://mms.orange.co.uk
Username: Orange
Password: Multimedia
MMS proxy: 192.168.224.10
MMS port: 8080
MMS protocol WAP 2.0
To check these
Open the default SMS app at the inbox, Menu>Settings>connection settings
To Change these
Download MMSzap HERE unzip the file and copy MMSzap onto the root of your SD card (Not in any folders)
Open your file explorer on your phone (Astro or Es file explorer) find the MMSzap.apk file and install it on your phone
Once installed, Open MMSzap on your phone un check Automatically copy active APN settings
Type the above settings into each field once you have filled all fields press back, you should get a Dialogue saying settings saved
Go back to your SMS app and check that the data under Production has changed
STEP 2
From your home screen MENU>Settings>Wireless&Networks>Mobile networks>Access Point Names
Select your Orange MMS settings when the detail window opens
Menu>Delete APN
BAck to the screen that Has your Orange Internet on
MENU>New APN
NAME Orange MMS
APN orangemms
Proxy not set
Port not set
Username Orange (Capital O)
Password Multimedia (capital M)
Server not set
MMSC http://mms.orange.co.uk/
MMS Proxy 192.168.224.10
MMS Port 8080
MMS Protocol WAP 2.0
MCC 234
MNC 33
Authentication type not set
APN type mms
MENU>Save APN
Good luck
Thanks to Pel for all his help
I can send SMS but no MMS :(
Ive gone through the settings about six times now to see if i had missed something or typed in the wrong code.
Solved - your 1st step didn't say what the username and password were so I realised they hadn't been entered into mmszap - they were only in the actual apn. Perhaps an edit of the 1st step of the instructions will prevent this happening to anyone else. In any case thanks a lot for getting mms working again for me Jaffa!
Thanks edited my bad
Ive gone through this again and still i cannot see what I'm doing wrong?
this time around the little round dot that was green has now disappeared!
Which green Dot, I only ever had one on my internet settings and were not touching them.. No green Dot is requied for this to work..
Looks as if it was a network problem i was having.
Photos that i sent this afternoon have just come through to my wifes phone.
Waiting now for her to send me one back .
Will report back.
Thats the settings Ive got right down to the decimal point.
Still waiting to receive a picture though.
Took a while but i'm finally there. downgraded from 5.4 to 5.3 and seems to have done the trick. Thanks for the guide Jaffa
Excellent stuff, nice on Jaff.
I got the Orange maps back on it now as well, so we're all up and running again.
Nearly used up my 50 free photo messages already !!!!!!!!! :-)
