Fulltime Traveler
Is there a way?
Try setting the Ring and Notification volumes separately. (Remember, this is Marshmallow.)I guess I miss the question.
If I go to Settings/Sound & Notification I can set the volume for ...
Media
Alarm
Ring
Notification
... Thom
...I got the Marshmallow update on my Droid Turbo on Tuesday. Now I have the same issue, ringtone and notifications are linked. There are separate bars to change the volume but they move simultaneously. Verizon & Motorola pretty much said it is what it is. No way to fix. Anyone know of anything? Thanks.
In all of these apps people are seeing multiple controls that they can set at different values and are assuming that they are been set the way they requested.
Set them and then check to see what got set. I think you will find that they are linked.
... Thom
Mine aren't. What will happen is the sound gets lower if you have vibrate on.In all of these apps people are seeing multiple controls that they can set at different values and are assuming that they are been set the way they requested.
... Thom
If you mean me - no they are not. 3 different controls. Of course, if another app that came with the phone does it, I wouldn't know. I've disabled or deleted 95% of them.I was referring to third-party apps.
On the Turbo and Turbo 2 ... Settings/Sound & notification has sliders for ...
Media... do you also have a slider for ...
Alarm
Ring
Notification?
The issue is that under Marshmallow Notification and Ringtone are always set to identical volume levels. Is this true for your phone?
... Thom
