How to set live wallpaper on Galaxy s7 edge
Colin_e1
I downloaded the fallout 4 live wallpaper on my phone, and I can't find it anywhere! Samsung themes is the stupidest thing Samsung's ever done. They should put the wallpaper screen back, and have Samsung themes as a separate application. But can anyone tell me how to set the Fallout 4 live wallpaper with Samasung themes?
I'm not sure about live wallpapers, but if you just want the fallout 4 background as your wallpaper. Open it in Gallery and tap on the 3 vertical dots (top right-hand corner). Then select Wallpaper. There is no need to mess around with themes
Well yeah, I know how to set a wallpaper, but not a live wallpaper that doesn't have its own app to set it.
To set a live wallpaper on your galaxy s7 edge, you need to install the live wallpaper app from google play store first.
Here’s how:
  1. Download a live wallpaper app from the google play store.
  2. Pinch on a home screen using 2 fingers, and then tap Wallpapers.
  3. Select the screen that you want to set a live wallpaper from the drop-down menu in the upper left corner.
  4. Select the live wallpaper at the end of the image scroller at the bottom of the screen.
  5. Tap Set as Wallpaper.
Samsung Themes for some reason wont't allow me to set a live wallpaper either. But I found a solution! Go to the Google Play Store, and search "Live Wallpaper Setter" and download the first app that's listed. Open it, and simply select the live wallpaper you want to apply. Easy! :):thumbsupdroid:
OH I FOUND IT AFTER SO LONG. OK so go to the wallpapers and themes, hit VIEW ALL in wallpapers, in the upper right (the three dots) tap it, and itll say LIVE WALLPAPERS. Dont feel stupid because that is how hard it is to find
hope this works ^^ for you as it did for me because i have the s7 edge as well
