Been trying to figure this out on my SGT but can't seem to get it to work. I set the pin in Security under settings and it just reverts back to the original don't lock setting. Any help is appreciated.
I followed those directions. You have to turn off screen right after you set pin in order for it to enable lock screen. Kind of an odd way for stock instructions but it worked. Thanks.
