I don't understand what you mean then. The Ace screen in 320x480, you can resize your image to that size on any computer, when you select it, resize the box to fit the whole image and you have a full screen wallpaper. If you have the settings to scroll, then your wallpaper needs to be 640x480 instead.
saurabhsunny25, I'm not totally sure if you are having the same issue as another member I have just answered, but I suspect you might be, so if so, give this a try:
I think you might mean the photo is spread over the two screens landscape-style (You can tell if this is the case by swiping right to left on your home screen, and if the rest of your photo is visible on the next screen, that is your issue).
To get the whole photo visible in the homescreen, go back to your photo in the gallery, choose to set as your homescreen wallpaper, then at the bottom you will see icons to set it as lanscape or portrait. Choose portrait then 'stretch' the box as large as you want the visible portion to be (or as large as it allows), then save.
Your photo should now be fully visible on your home screen.
