Help How to setup ringtone for SMS
djkiernan
I'm going crazy trying to setup a personal ringtone for SMS notifications... is it possible that there is no way to do that? When I go to settings and then to notifications, for incoming messages I can only select from the list that is provided with the phone, I can not define a custom tone.
Can anyone help?
Thanks in advance.
On the internal SD card (I haven't tried if it works on the external one as well), create these directory structures :
\Media\Audio\Alarms
\Media\Audio\Notifications
\Media\Audio\Ringtones
The files you put in these three folders will automatically show up in the selection lists when configuring the sounds for Alarms, Notifications and Incoming Calls, respectively
