How to speed up s3
Root won't speed it up. Flashing a kernel that allows speed control, then setting the speed higher will. Bit a) it totally voids the warranty and b) could cause your CPU to overheat and die (which would cost you a whole new motherboard). And the amount of speed increase you can get is hardly worth the effort.
Just putting a much lighter aosp based rom on it (without overclocking) speeds the s3 up considerably though :thumbup:
What is it that you want to be faster though? Gaming, user interface, internet....?
