i'm with mobilicity with a samsung mini, i just started with the plan and i was wondering how to get the data working? my plan has data but its saying there is no internet connection. How can i get the dat?
Check you have data enabled - in stock android this is:
Settings .. More .. Mobile Network Setting
Then ensure that Data enabled is ticked. The options may be slightly different on your Samsung.
If it is and you're still not getting an internet connection (while you have bars and a 3G or H symbol), then you need to contact your network to inform them that there's an issue with your account.
