How to switch audio between dock audio and bluetooth?
JeffDerek
I have a Galaxy Nexus on Sprint running Android 4.2.1. I use an LG Tone bluetooth headset when walking around during the day, and I have the Nexus car dock with the Pogo Pins for connecting the charger and audio out to my car's aux in.
If my bluetooth headset is off, and I put the phone in the dock, all media audio from all sources goes out of the car dock output and into my car's aux in, and everything is fine. Similarly, if the phone is not in the dock, and bluetooth is on, all media sources go to the bluetooth and everything is fine. Unfortunately, if the phone is in the dock and bluetooth is connected, everything still goes to the bluetooth. This is bad because I want the bluetooth connected for calls in case the phone rings, so I don't want to turn it off, but I want the media audio to go to my car speakers.
In the past, no matter what app was playing media (I use an audiobook app and a podcast app in addition to google play music), I would go to google play music and there was a button to switch between the dock speakers and the bluetooth speakers. It was cumbersome and a pain, and I kept meaning to find a way to make it happen automatically, but at least it worked. However, Play Music just updated and now I don't seem to have that button anymore. Now if the bluetooth headphones are connected and the phone is in the dock, the audio comes out of the headphones only, and I can't find any way to change that.
My ultimate question is this
1) Can I change the priority so that the car dock is a higher priority than bluetooth for media? I still want the bluetooth to be the highest priority for calls.
2) If not, can I at least get back the audio output switching functionality that used to exist in Google Play Music?
Anyone have any ideas at all on this? I'm open to any suggestions. I know this used to be possible and it's weird that the ability should just be totally gone, so there must be some way to route the audio where I want it!
I'm not totally certain of your situation, but have you tried Tasker? It should be able to make your phone perform like you wish based on which condition your in. It works like a champ on my GNEX.
I did try Tasker, but I couldn't find any way to control bluetooth media audio on it. I could either disable or enable bluetooth, but I couldn't dig as deep as I needed to make the necessary change.
