I read the thread about removing some apps that's not needed.
I tried and it seems like I removed something important, so I'm reinstalling the device now.
I see apk and odex files. Do I remove both of them?
Do I have to remove everything in dalvik-cache?
Thanks.
You have to adb push it
did anyone get ADB working for Linux yet?
BH_MAN,
when i type in adb devices, it shows mine as offline...whats up with that?
list of devices attached
SGH-T939 offline
thanks thought it might be useful in this thread
ok, i am trying to get my faves back on my phone. i just installed the no_twix ROM from BH_MAN. MyFaves.apk is saved on my C: Drive (C:\MyFaves.apk) I have adb pushed it to system/app (even shows the file when i check using ASTRO, but no icon in my app drawer) what am i doing wrong? here is the command line i use:
adb push C:\MyFaves.apk /system/app/MyFaves.apk
which gives me this:
439 KB/s <1222389 bytes in 2.713s
so what am i missing?
also, i have both the odex and apk files related to MyFaves, but the odex file gives me the same message (with a different file size)
when i adb push mms.apk /system/app
it will never let me send messages only receive i have to use like handcent to send messages....how do i fix that this happened on the last update also when i pushed it, it wont let me just install it either from app installer
adb shell
rm -r Mms.apk
exit
Just run those to make sure you don't have any dirty file's in the /system/app.adb shell
cd /system/app
rm -r MyFaves.apk
rm -r MyFaves.odex
exit
Once again!!!
You have to Rename the Mms.apk to TwMms.apk before pushing the File....
After you Push the Newly renamed TwMms.apk you need to do a Factory Reset to clear out the old dalvik-cache!
I noticed this too, I pushed it both ways, as Mms.apk, and TwMms.apk, and I couldn't send messages, only receive until I downloaded handcent. I wiped the data and everything, still no go. I prefer handcent anyway, which I why I replaced the original TwMms. so I'm not complaining or anything.![]()
adb shell
cd /system/app
rm -r Mms.apk
rm -r TwMms.apk
rm -r TwMms.odex
exit
Here's the File you need...
Before pushing the App...
Download MyFaves.apk
adb push ( File location of MyFaves ) /system/app
