How To Turn Off Dark Mode On LG K20 Plus
startac4
I inadvertently pressed some button(s) that i don't which ones and now my LG K20 Plus cell phone is in Dark Mode. How do I get it back to normal? Settings -> Display does NOT have an entry for toggling Dark Mode on/off.
i have never owned an lg phone so i do not know where to exactly look for it. but you should have a search button in your phone's settings. look for a magnifying glass icon in settings. you should be able to do a search for dark mode. it might be called night mode or something similar.
Thank you ocnbrze and olbriar. I didn't find a magnifying glass. And DISPLAy in SETTINGS does NOT have a Night Mode entry. But I did come across in the top (notification?) bar when I pulled it down "color inversion". When i pressed that the phone went back to a normal display. So it's good now..
Yeah always play with that top first to really suit your needs.
