How to turn off QSlide
Markus729
I swear I found the answer on this forum not too long ago, but after doing a search, nothing came up.
I just did a factory reset after the KitKat update, and I want to remove the QSlide section of the notification panel, it takes up too much space.
Anyone remember how to do that? thanks in advance!
In the notification panel, all the way to the right click edit. Find qslide and check it. Then leave the edit menu and de-select qslide from the notification panel. Then back to edit to remove it from your choices. Done!
Thank you! I didn't realize you could get rid of that & I'm glad to have it gone :D
Thanks for this! I had shut off all the qslide apps but the edit button was still there taking up space!
