If you are looking for the stop button, you need to press and hold the play button or pause button inside Poweramp
rlugo29 - did you every figure out how to "turn off" poweramp?There doesn't seem to be a stop button or exit button. I only see a pause button, but then the app is still running in the background. Besides going into my phones app manager after every use how else do you turn it off????
This one is also helpful for changing auto-run permissions https://play.google.com/store/apps/details?id=com.seasmind.android.gmappmgr&hl=en
