How to turn on my S9 with broken power button
Hello,
Can anyone help me, is here any way to turn on my Galaxy S9 without using power button.
I saw some videos and texts which suggest to press and hold Volume down button and to plug the USB cable to PC and phone but it only is charging the phone, I'm not receiving the warning message. Some time a get vibration and red light, nothing else.
Is there any other way to do for example any Windows app or any other trick I can do?!
Thanks in advance
nope sorry, once the phone is off, its off. there is nothing that you can do other than get the power button fixed.
Well that's definitely not true
Thanks in advance
Try holding both Volume buttons, while you plug it in. If that doesn't work, then try Volume Down together with Bixby
