sammyz
LG Whiz Kid
Ok so you bricked your phone somehow and you need it ASAP!
Just follow this. Skip to step 3 if you have installed drivers already before.
Step 1: Get drivers here and install them
LGUnitedMobileDriver_S4981MAN37AP22_ML_WHQL_Ver_3.7.2.exe
Step 2: Reboot
Step 3: Make sure phone has at least 50% battery
Step 4: Get firmware here
http://androidforums.com/optimus-net-all-things-root/615149-firmware-lgl45ct2_01-a.html
Step 5: Download this and extract
KDZ_FW_UPD_EN.zip
Step 6: Put phone in emergency mode
Step 7: Follow these steps in order (This is from the extracted "KDZ_FW_UPD_EN.zip" ZIP)
Step 2: Reboot
KDZ_FW_UPD_EN.zip
To put the LGL45C into download/emergency mode:
1. With the phone powered off you hold Volume Down and Back at the same time.
2. While holding the keys insert a USB cable plugged into a PC or charger, in a couple of seconds the the screen should say emergency mode at the bottom.
Hope this helps!
- Install msxml.msi
- Disable antivirus software
- Open UpTestEX_mod2_marwin.exe
- Wait for the program to open
- Look for "Encrypt cab file to kdz file"
- Click the folder icon
- Choose the location of the cab you downloaded for L45C firmware
- Encrypt cab -> kdz Program will freeze up. DO NOT EXIT until program says Done!!! Otherwise it won't finish converting.
- Close program
- Open KDZ_FW_UPD.exe
- "Type" choose CDMA
- Choose in "Phonemode": Emergency
- Click the folder icon and choose the kdz file that UpTestEX_mod2_marwin.exe just made.
- Click Launch software update and enjoy!
i get the same error has anyone found a good .cab file yet?
