Root How to uot .
adanmex
. Lastly any news on Over clock and cm7/9 or new full roms . Thanks for your help and awesomeness
what i did was, pull the framework-res.apk and SystemUI.apk from the phone, make any adjustments/mods that you want in the kitchen. in the upload section of the kitchen upload both of the files above, choose the edify method and submit. now you have two choices on installing the theme, either flashing it through cwm or creating a metamorph theme. I chose the later, as i was unsure how it would flash through cwm. if you do make a metamorph and do it that way, it takes some time for the theme to install and will seem as if it is not working. just be patient and let it run, it may take about 2-3 min to finish.
ive been messing with it to but when i go to flash it it aborts so i don't think I'm doing this right. can it work on the stock rom?
this is what it says when i try to flash it:
finding update package...
opening update package...
installing update...
amend scripting (update Script)
supported.
amend scripting was deprecated b
ndroid 1.5.
it was neccesary to remove it wh
to the clockworkmod 3.0 gingerbr
overy.
please switch to edify scripting
ipt and update-binary) to create
te zip packages.
installation aborted.
supported.
ndroid 1.5.
overy.
te zip packages.
In the upload tab switch your scripting to edify. That should fix your issue. Stock rom is supported.
