How to upgrade android software?
sarmadali
hey guys me new on this forums
just serchd and found this
i want to know is how to do upgrade anddroid
i have is
2.3.6
thanksssssssssssss
Typically if you have a Samsung device you can download the Kies software, with this tool it will allow you to update your device to the lastest version of android, if it is available.
With HTC I know you can use HTC Sync, I believe but am not 100%.
If anything I would suggest to contact your carrier, because they are usually in charge of releasing updates to your device.
