SilverDroid
I need to be able to use hidden/internal API's with Eclipse.
Ive read the guide here Using internal (com.android.internal) and hidden (@hide) APIs [Part 4, customizing ADT] devmaze though it doesnt work for me.
Has anyone else got this to work? if not, what have you had to do?
Edit: At the end of the guide, dont extract the jar like he says. Instead, view it within 7zip viewer, and make the change direct. It will then work
As a side note, I still have one error "The import android.os.SystemProperties cannot be resolved"
If anyone has any ideas, please do let me know
